Install exhaust pipe clamps. At an earlier date we put the clamps on the exhaust pipes with Bob Eggelston. The clamps were fastened at this time just enough to be able to move them. This time I measured and cut the clamp tubes to have about an inch gap between them when the hose is slipped on. I had to cut only two tubes in place. These were the ones that fatened to the two exhaust pipe clamps. The others I removed and cut on the bench. After the tubes were cut and reinstalled I slipped on the hoses and tightened all the nuts and hose clamps.
