Brief Description: Install plate-nuts on wing ribs
Install 4 10-32 (K1000-3) plate-nuts using MK 319-BS rivets. the Duckworks rivets included in the kit did not work (too soft, did not pull in properly, ended up lose). The plate-nuts are placed on the outside of the ribs that form the mounting plate. Because of the pop rivets supplied by Duckworks this was a very bad day.
