These connections are shown on the "Wire Connection Diagram". Connect the Headphone and the Mic wires as per the above Diagram (4 and 5 detail). Used the sub-D crimp-on pins. These connections are very time consuming. I was able to work because the temps are a bit higher. I was able to maintain 50-55 degrees in the garage.
