Got Back from Phoenix yesterday after a month stay. Previously I left too much wire for the SL30 Com and Nav and the GTX330 power connections and today I shortened these wires. I also pulled the wires from the EFIS harness for the SL30 connection. Will replace these with the cable comming from the SL30 unit that provides shielding. I have a few choices here, but I decided to connect the wires at, and very close to the EFIS connctor instead of pulling the pins out of the connector and replacing them with the wires from the SL30 cable (this would be a pretty nasty job). I think this will work.
