Two days of 1+ feet of snow. Couldn't do much, lots of shoveling and too cold. Today I wired up theRay Allen led typer indicator and switch for the pitch trim using Bob Nuckols description (A "Little Connector" Solution for MAC Servos). This is only the female side of the Sub-D connector. The other side will be wired the same way to the trim motor wires. Really works well I will have to add the glue to stabelize the wires although it looks pretty strong as it is.
