Since the Garim 496 GPS will need only 1.5 amp fuse I decided to get the power from the battery bus. Because the battery bus is not connected to the EXP BUS I installed two switches on the left side of the left panel for the GPS power and the Angle of Attack power both of which will come from the battery bus. I want to be able to control the power to everything that is connected to the battery bus.
