Brief Description: Re-paint left panel, flap wires
Decided to re-paint the left panel due to wear and tear problems during installation of the avionics system. Also re-painted the bezel for the TruTrak autopilot for the same reason. Also updated the wires for the flap and flap switch. Extended the V- (ground wire) to the Up/Down flap switch and run a new ground wire from the switch. The schematics clearly shows this configuration of wires. With the exception of a second com unit the left panel is essentialy complete. not much future installation wear and tear.
