Brief Description: Upgrade the EIS as per instructions + misc.
Add the extra wire for the second tach display using pin 24 on the connector according to instructions. This was necessary after the EIS upgrade. Add the battery bus cable (#16) and pull cable into cockpit side of the firewall. Add a connector to the battery terminals for easier charging (3rd picture). I should be able to access this through the cowling door. I am using this now to trickle charge the battery. Document the fuse assignments.
