Install the current sensor and add the wires to the wire bundle. I split a rubber hose and installed it on the power wire to give some ridgidity to the sensor. Used 3 wire ties to hold the sensor. Fasten the manifold sensor to the middle bulkhead behind the EIS and addaed the wires to the wire bundle. Also shortened the plastic tube between the firewall and the sensor.
