Design and lay-out the main power wire location between the ANL current limiter and the EXP BUS Battery connection. I decided to run the #6 wire along the cockpit side of the firewall as shown on the pictures. The wire is held in place by Adel clamps. This was a two day project, quite difficult to bend the fat cable, but it turned out really good. I had to lay out the cable first temporarily to figure out the proper length and than I cut the cable to length. Next I put on (crimped) the connctors and reinstalled the cable. Drilled the hole on the firewall to 1/2" and used two plastic gromets for the cable. Will seal the firewall hole with red high temp sealer. I wished we have more picture frames for each entry in the software.
