Brief Description: Epoxyed the reinforcement plate on wing tip
Epoxyed the 1/2" reinforcement plate on the wing tip. Used the System Three T-88 epoxy. Roughed up the aluminum strips and put epoxy on the fiberglass side and on the aluminum strips. Dipped the cleco tips in Petroleum Jelly to prevent them from being glued to the wingtips. I removed the clecos after about 4 hours before the epoxy set up to hard consistency to be on the safe side. Worked out really good.
