Drilled a two of excess holes for the EIS and EFIS cables and installed rubber gromets to protect the cables. One hole was drilles in the F-7107-R FWD Fuselage Rib between the panel and the F-7105-R outboard sub-panel (EIS). The other was drilled in the F7105A center sub-panel for the EFIS cable. Had to shorten the right radio stack mounting angle since it interferred with the F-7103C-R attach angle. Check for more interference. So far so good. Worked on the layout for the cables forward of and behgind the firewall.
