Rerout the pitot tube wires (+ and ground) inside the large wire tube and pull the strobe wire close to the main spar of the wing where pitot wires were located before. Using a slodering iron I installed the wires into the pitot tube plug. Test fitted the pitot tube through the opening in the wing skin. Looks good for later installation.
