Make support angles for center radio stack. Had to cut out a hole for an already installed platenut in the panel frame. These are two of the many fasteners for the left and the right instument panels. The oval holes are visible on the pictures. Took a long time to do a good job. Check the preliminary fit for the Garmin 496 Airgizmo support. Because of an apperent error on the part of the modular panel people in designing the frame I will have just enough room to install everything in my radio stack (Garmin 496, GTX 330, SL30, GMA 340)
