Brief Description: Cabin heat flange (rear right baffle)
Cut out and glue on the metal screen on the cabin heat flange to prevent bugs, etc. to get into the cabin. After the glue dried riveted the flange on the right rear baffle. It was impossible ti rivet one of the corners so I used a screw with a nylock nut. The nylock nut was placed on the outside of the baffle same as the ignition cable guide.
