Brief Description: Drilled holes for cooling blast tubes
Drilled holes for the cooling blast tubes on Part 10 for the alternator, Part 2 for the right magneto and Part 6 for the left magneto. I also decided to use platenuts for fastening Part 5 and Part 6; installed three platenuts. It would be impossible to install part 4, 5 and 6 as one piece. Also drilled the holes for the platenuts between Part 7 and 8 for the same reason.
