Brief Description: Fit Part 10, right front air inlet floor.
Fit Part 10. The hardest part was to fit this piece to the lower cowling and to find a way to make an access hole for the prop control oil line. I finally setteled down with the configuration shown on picture 1. I must have took this piece on and off a hundred times (maybe I am just frustrated). Made Part 10R as show in picture 1 and 2. I also made a cover plate for the cut I made for the prop control oil line. I had to make a filler piece to fill in where I cut the access hole for the oil line (I glued the two pieces together). Fit Part 16 the same way as on the left side using a velum piece to transfer the screw hole. Installed the platenuts on Part 16 and drilled the screw holes in Part 10 and the filler piece.
