John B.s Web Site
Date:  1-6-2007
Number of Hours:  1.00
Brief Description:  Fiberglass VS and Rudder tips
Fit fiberglass vertical stabilizer tip, mark where the tip has to be cut. Make required cut. The end of the tip will have to be closed at a later day when temperatures are warmer for fiberglassing. Fit and trim the rudder tip. Drill and cleco the two tip on the rudder and vertical stabilizer. I will install the rudder tip with screws and platenuts. I am not sure what I want to do with the VS tip.
