Drilled the holes in the windscreen for the rivets/screws. This is a very tedious job, one hole at a time. I had to use a few shims on the left side, a bit more on the right side. Came out almost perfect. There is less than 1/32" difference at most between the canopy and the windscreen and most of it is right on the money. The third picture shows the worth spot. Never thought this will turn out that good, but I will take it.
