Fitted the canopy skirts to the canopy frame and starting at the front, drilled #40 and clecoed to the frame. Removed the skirts from the frame and deburred all the drilled holes. Modifyed the C-759 Inside Canopy Skirts as per DWG 41, pre-curved it to match the curve of the frame side tubes. Layed the C-759 against the inside surface of C-660, lining up the back and top edges of the two parts. Seem to align the notch I put into the C-759 with the front bow of the canopy frame. Then using the C-660 as a drill guide match drilled four holes evenly spaced from fron to back in the C-759 using #40 drill. Cleco C-759 and C-660 to the canopy frame and holding C-759 and C-660 tightly against the canopy frame I drilled #40 and clecoed working from front to rear.
