Took measurement on the canopy frame and C-791 braces to be sure that the pattern that I will drill on the C-660 will work. Everything looks good. When I layed out the rivet holes on the canopy side skirts I took extra care to take this into consideration. Since both canopy skits have the same hole pattern I clamped these two pieces and drilled them at the same time.
