More bending and fitting. I must have taken on and off the canopy frame from the fuselage a 1000 times. I had Bill Arnold come over to check the canopy and frame fit. He thinks I should drill the front and back bows to the canopy. So I decided to end the agony and just do it. Drilled the front bow. In order to make sure everything line up I camped the sides and the back bow and made sure all the edge distances were right. Used #40 drill.
