I designed and made a small aluminum box behind the central console to basicly protect and hide the swithes and wires that will eventually go here. The central console uses the VAN's mounting angle and the two small mounting strips at the bottom. These will be match drilled to the existing holes on the fuel selector mounting plate screw holes. Thsi design will make it really easy to take off the center console if access is needed and no new holes are drilled. Next is deburring, riveting and primeing.
