Match drill and deburr the two halves of the mapbox as supplied in the kit. Mark the cutout dimensions on the F-07105B outboard sub-panel. This was everything but easy because the panel is quite easy to bend at this point. The bottom line was quite accurate so I corrected the upper line by using the dimensions given in the manual. Hope everything will be OK.
