Cut the cable to the proper length as previously marked with the dremmel tool using the cutting wheel. Installed the control cable, but left an extra lenght of the inside core for later adjustment when it is permanently installed . The cable is attached using a drilled bolt and several washers in the arm of the stainless steel heat box. This is quite ingenious since I will be able to adjust the door of the heat box at any time.
