Rivet Gascolator Mount assembly and drill three holes on the mount for the gascolator. Two of the holes are used to bolt the gascolator to the mount, the third is used for the primer line. In my case it is pluged with a blanking plug since I do not used the primer. The primer port can be used to feed a pressure transducer.
