Cut to size the braded fuel line hose and install connectors (6). Connect to Fuel Valve and Facet Fuel Pump. Left approximately 3" of hose outside of fuselage skin for connecting to the wing. This can be adjusted since the line is quite flexible. I left a bit more than needed rather than run short.
