Match drill 5+2 holes into both fuselage side skin and gear leg mount for AN4 bolts and screws as per DWG 34A. Deburr all the holes and touch up gear leg mount. Put gearleg mounts in place, make sure all bolt holes are aligned, install bolts and torque all bolts and scews. This was a time consuming process since I wanted to make sure everything fits perfectly.
