To align the pitch servo push rod with the elevator bellcrank it was necessary to make a 1/8" back plate for the servo bracket. This was a timeconsuming process involving lightening holes and holes cut for the already installed rivets on the elevator bellcrank rib. Lots of mearurements and fitting. Install the pitch servo in the fuselage as per TruTrak drawings.
