Brief Description: F-680 and F-661EF Flap Bearing Blocks
Drill 2 #10 holes in F-680 Flap Bearing Block as per DWG 33. Notch corner of block as shown on DWG 33. Saw in two the bearing block as shown on DWG 33. Drill one #10 hole in both F-661EF flap bearing block. Install on WD-613-EF and bolt on to F-705D-L&R. Match drill second hole in assembly in each flap bearing block (Drilled in only about an eights and then finished the hole in a drill press). Using the holes in F-680 flap bearing block match drill the F-727-L indoard baggage rib and F-747-L baggage floor.
