Install WD-655 break pedal assembly in fuselage. Drill three adjustment positions for the rudder/break pedal assembly and fit at each position. This has been a very time consuming process since I did not have the proper drill bit length for the angle drill to reach all the way though the bearing blocks, so I had to mark each position on the forward skin stiffeners using the rudder pedal bearing blocks then remove the blocks and drill the adjustment holes on the stiffeners.
