Brief Description: Aileron hinge bracket and conduit
Match drill and countersink the W-913 and W-914 aileron hinge bracket assemblies. Cleco the assemblies together and rivet as per DWG 13. Rivet both hinge bracket assemblies to the right wing. Match drill the conduit supporting plates to the wing ribs and deburr. Countersink the supporting plates. Rivet supporting plates to wing ribs. Install conduit in right wing. Tie the conduit to both ribs on two sides of the inspection hole.
