Ream brass bushing. Drilled a guide hole 3/8 diameter to hold the bushing, inserted bushing and used 1/4" drill to ream the bushing. Worked really good compared to the first (left wing) attempt. Install bellcrank on wing. Had to remove the mounting bolts from the spar to clear the large bell crank bolt.
