Brief Description: Mark and drill holes for 10-32 platenut
Fit the rib shaped tamplet into leading edge and mark A and B locations on both ribs. Drill A and B holes in both ribs with #30 drill bit. Cleco the the 10-32 plate-nuts in the holes and match drill with #40 bit using the platenut as a guide. I placed the plate-nut on the inboard side of the mounting bay for the inboard rib for easier access. These two holes are impossible to drill from the second bay. Later I moved the plate-nuts to the outside of the rib for riveting. Drill the screw holes out using 3/16 drill bit.
