Brief Description: Glue the trailing edge together
Sand and clean the AEX wedge and both skins along the rivet holes at the trailing edge. Mix T-88 epoxy adhesive and coat the AEX wedge. Place the wedge between the skin and cleco all the pieces together including the aluminum angles on both side of the skin. Clean up the adhesive. Used petroleum jelly on the clecos and between the skin and the aluminum angels to prevent them from sticking to the skin.
