Cut out inside holes on the aileron push rod boots mounting rings. I used a nibbler tool I have. This, although very time consuming, it turned out not bad. Cutting the inside hole to the right diameter was the most time consuming job. Drill the mounting holes. Tomorrow I will try to fit the boots and install the platenuts.
