Bob Eggleston came over to help me install the left wing using hardware store bolts (7/16). The going was pretty difficult. We managed to install the top two large bolts by moving the outboard end of the wing up and down gently. One of the lower bolts went in by hand the same way. Clecoed on the wing root fairing to check for clearance from the fuselage side. The fairing is per-dilled and pre-cut and the fit was quite good. Decided to take off the wing and install the fairing platenuts on the bench. This will give me better access to do a good job. The saw horses came pretty handy. I could not imagine doing this job without them.
