Discuss the large hardware bolt problems with VANS. Scott said it is OK to tap the upper bolt in, but just put the lower bolts in partially to make sure they can be removed. He said the final bolts will not be damaged because they are steel and the center section is aluminum. I decided to make two saw horses for supporting the wing as we mount them.
