Brief Description: Install AOA tubes, Marker Beacon cable, etc.
Cut the AOA tubes at the wing root and installed on the AOA computer. The tubes will be reconnected once the wing is installed. Extend the Marker Beacon cable for easy access for a later installation on the marker beacon antenna. Move the fuel breather tubes further away from the sides of the fuselage. This will make it easier to rivet on the front top skin. Make a bracket for the parking break cable
