Check Autopilot connection thru switch to EFIS and GPS output. Checked out OK. In the up position the autopilot is connected to the GPS in the down position it is connected to the EFIS. Connect pitot and static hose to AOA computer. Check flap switch wire for continuity. It is OK. Warning light for EIS has to be fixed.
