I started on the installation of the Angle-Of-Attack unit. Put the control box on the right forward fuselage rib. There is just enough room for the mounting brace. I had to form the mounting angles to make a workable fit. Once that was done I made a template for the mounting screw locations, placed the template over the forward fuselage rib and drilled the mounting holes. Prime the mounting angles.
