We routed out cracks on co-pilot and pilot side control stick area. Troy vacuumed out cockpit and fuselage areas and installed screws in baggage compartment for floor panel. We fixed fuel leak at fuel flow sensor. Re-clocked lower oil cooler 90 degree fitting from hitting on engine mount. Troy inspected fuel selector valve connections. Calculated fuel flow, did high power run for MAP, RPM and FF (I taxied the aircraft for the first time with Troy to Runway 15). Continued safety check of the entire aircraft for safety.
