Brief Description: Connect Magnetic Compass Light Wires
Decided the layout of the wires and connected the ground wire to an existing plate nut point behind the EIS bay. Decided to use a small "push on/off" switch and install it next to the EIS switch. It will be a little crowded, but I think it will work. The 12V for the magnetic compass light is pulled off of the EIS switch.
