Configure Garmin 496 for TruTrak autopilot and ADI.Start the ground check procedure for the autopilot.The movement of the pitch servo is incorrect. I will have to check the jumper between pin 1 and 2.Check autopilot connections for EFIS, EFIS does not have good connection to autopilot. Looks I will have many days on this electrical, avionics check.
