Brief Description: Install rear rod end bearing to attach brackets
Install rear rod end bearings on A-907 inboard attach brackets. Had to trim the bolts to clear the notch in the nose skin. The bolt cutter that I had just would not do the job so had to use the hack saw to trim the bolt. This took a lot of measuring and re-measuring, but got the required two threads protruding from the nut. Also had to trim the left spacer to make it fit. Originally it was cut 1/32nd larger than needed. It will not fit without trimming it. Lots of small steps added up to 2 hours.
