Brief Description: Right Flap Control Rod Fuselage Hole
Since I already knew the approximate shape of the hole from the left side and was able to find the right position I finished the hole to close final size in 2 hours. I am sure I will have to make additional adjustment after I hook up the pushrod. The discoloration on the fuselage skin is from light reflection.
