Install the Tosten Manufacturing Control Grip on the left control stick. Measured the clearence between the control grip and the panel. Cut the control stick, filed and sanded the cut and drilled the screw hole using the #12 drill. The location of the screw hole had to be accurate so it took some time to locate, but in the end it turned out great.
