Drilled and cleco ribs to skins for left aileron. Aileron has a 2.5 degree twist to provide washout. A spacer is used under the outboard trailing edge to provide the proper twist. This is a 13mm spacer.
Detaill of ribs and end of aileron which is at a angle to match wing tip.
