Scotts Zodiac XL
601XL
6-T-6
Elevator trim
Shaped the trim tab, mounted the hinge in the elevator fist then drilled to the trim tab with tab held in proper location. Prepared all for riveting and riveted the next day.
Also, made and drilled access plates for the servo hole.
Hinge drilled
Hole for servo connecting rod
Trim tab drilled
601XL Home
Ailerons
Flaps
Horizontal Stab
