Drilled and riveted the horizontal stabilizer tips. This was pretty easy and the fit is good. Although, later I'll learn that the best technique for ensuring level when mounting to the tail is to use a level set on an L angle to the end rib. So, I may have to remove these when I mount to the tail.
